Display information about the UDP forwarding characteristics of the device. UDP forwarding only supports 128 entries.
Display the UDP protocol table with the UDP port numbers for each supported or designated protocol:
Switch:1>enable
Switch:1#show ip forward-protocol udp
Udp Protocol Tbl - GlobalRouter
UDP_PORT PROTOCOL_NAME
37 Time Service
49 TACACS Service
53 DNS
69 TFTP
137 NetBIOS NameSrv
138 NetBIOS DataSrv
Use the data in the following table to use the show ip forward-protocol udp interface command.
Variable |
Value |
<A.B.C.D> |
Specifies the IP address for the interface in a.b.c.d format. |
vrf WORD<1–16> |
Specifies the name of the VRF. |
vrfids WORD<0–512> |
Specifies the ID of the VRF and is an integer in the range of 0 to 512. |
